Immobilizer alarm security reset?
KHLOW2008
  • 41,814 POSTS
Hi manuelg,
The radio going off could be due to internal fault or loose wire connections. Check connections of wire socket behind the radio.
When alarm self triggers it is normally caused by doors out of adjustment. Check if any of the doors are loose and the switch operates when slight movement is detected.
Saturday, September 26th, 2020 AT 1:22 PM (Merged)
AMORITA
  • 2001 HONDA ACCORD
  • 6 CYL
  • 4WD
  • 110,000 MILES
My alarm going off for no reason
ZACKMAN
  • 4,202 POSTS
Start by checking your battery. Weak battery will cause the alarm to go off. Turning the light switch and check for light operation IS NOT checking the battery.
Bring the vehicle an auto parts store for a complete electrical system.
PJO
  • 2001 HONDA ACCORD
Computer problem
2001 Honda Accord 4 cyl Front Wheel Drive Manual
How do I reprogram immobilizer control unit. Thank you pjo
DAVE H
  • 13,384 POSTS
PROGRAMMING
the keys and the car must be plugged into a computer and be programmed together?
TRANSPONDER KEYS
Programming must be done with all keys present, using Honda PGM Tester and immobilizer program card. Any key that is not learned/reprogrammed will no longer start engine. The immobilizer system can store up to 6 key codes.
JOLPOT
  • 2000 HONDA ACCORD
  • 4 CYL
  • 96 MILES
My car alarm starts to go off for one of the 2 reasons(rain and heavy winds OR when hood is opened) or a combination of both
Last fall, I took it to the local mechanic for an inspection and brought the car home(it was very windY), the alarm went off within half hour.
Last monday, I took the car to the local honda dealer, they couldnt reproduce the issue. Nor offer me any helpful info. Glad I didnt have to pay the 120 in diagnosis fees!
I called American honda owner link, this is what I was instructed - when the alarm goes off, using the master key insert it into the driver door and turn all the way to left, then all the way to the right and then all the way to the left. The alarm stopped, I took out the key and unlocked the car and locked it, it armed itself again! I thought problem solved!
Yesterday, I came back from a timing belt service and it rained last night and the alarm went off this morning.
I have removed the horn relay since it has been going off every 5 minutes.
One thing I noticed is that when I press hte lock key, the LED light on the drivers door blinks 8 times and pause and then starts blinking every 2 seconds. After the call to American honda, it probably blinked 6 times before pausing and blinking every 2 seconds. Is there any secret code to this? Is the Honda Accord telling me something? Please help. This id driving me nuts.
Also, is it possible to disable the hood latch security thing so that the ACU always thinks the hood is closed?
Your help is most appreciated.A really sleepless and helpless owner
Monday, September 28th, 2020 AT 12:22 PM (Merged)
KHLOW2008
  • 41,814 POSTS
I would suggest checking the hood switch adjustment. When hood is closed, there could be too little contact between switch and hood and any vibrations such as from wind, rain or even vibrations from passing vehicles, the alarm would be triggered.
The hood switch is most likely out of adjustment resulting in minimal contact from the hood to break the circuit when hood is closed. Rain water getting to the switch can result in the switch being turned on.
Under windy conditions, vibration of the hood would trigger the alarm as the hood switch comes into contact.
At the point where the hood switch contacts, get someting to stick on the hood to increase the amount of contact when hood is closed. Alternatively, if it is possible, try to increase the height of the hood switch by means of adding a thin spacer betrween it and its mounted position.
If it is possible to adjust the hood so that it closes tighter and do not allow any movement, that would be the ideal solution.
JOLPOT
Thank you for your immediate response - How do I get something to stick on the hood(do you mean the rectangular bar on the hood?). Also, how dyou increase the height of the hood switch and/or the hood switch. Mere googling these terms did not provide me any straight forward answers. For now, I have removed the horn relay and the cr2025 cell from my keyless entry and using the key the old fashioned way to get in and out of the car.
When I closed the hood, I did slightly pull it up to see if there was a play after the hood was shut and there wasnt any and that made me happy.
I am however very curious to clean the hood latch thoroughly, get rid of the gunk/grease and do what you have suggested. Only if I could find a mechanic who understood everything you write.
Please write
thank you
KHLOW2008
  • 41,814 POSTS
If you look around the perimeter of the engine compartment with hood open, you should be able to see a rubber capped switch that can be depressed. It is seated too low. Try to get it seated slightly higher than present and the problem sjhould be solved.
If you teell any mechaninc that the hood switch is out of adjustment and has too little contact with the hod when hood is closed, he should be able to help you on this.
JOLPOT
Thank for your response - I will go see a mechanic and explain what you have written.
However, what I see on my hood latch is the switch is actually plastic, bluish in color(thats what I think is the switch which gets fed 2 wires probably from the drivers MCU and ground). And has a metal contact strip jutting out of it. Say about 5mm width and nearly an inch or inch and half length before it vanishes into the blue switch/under it.I could touch the strip and whats really odd is this strip can move up and down. And couldnt understand what its position should be and If it needed to be secured.
Thank you for the message. I really appreciate your kind gesture!
Basically, this is what I did - took the car to a mechanic, had him remove the hood-pin switch. This switch is so close to the radiator that I nor the mechanic could reach via a screwdriver or any other gizmo. So, he had to remove the hood latch and remove the hood pin switch. I think he just removed it, no short nothing.
Ever since that day, some parts of the sec system(auto lock) don't work, but if I lock the door, the security led on the drivers door panel lights up and no more alarms in the middle of the night. Which is all I wanted.
Hope this helps other poor Honda accord car owners like me. Call American Honda owners association and they gave me the Right-Left-Right combination of key in the drivers door ONLY WHEN THE ALARM is going off(it is very important, only when the alarm is blaring away this will work), this supposedly resets the security system.I had some luck with it initially, however, when there was rain/wind next time, it went off. Thus the smoking gun in my case was the hood-latch and hood-pin switch
please let me know if this is the switch you are talking about.
Thank you again for your help
KHLOW2008
  • 41,814 POSTS
I believe that is the correct switch. When the the strip is moved downwards, contact is broken. How high it should be seated depends on the distance between the hood when closed.
Try using a small cap on top of the button and see if problem is solved.
