2003 Honda Accord clunking noise on hard acceleration
2003 HONDA ACCORD
81,000 MILES • 6 CYL • FWD • AUTOMATIC
SYED PIRZADA
  • 5 POSTS
Clunking / crackling noise coming from driver side when turning right and also under hard acceleration going straight. Only lasts a couple of seconds. Already changed c.v joints, spindle, hub assembly, lower control arm, brake calipers on both sides. Running out of things to change, but noise is still there. Have had the transmission checked, it is okay. Tried to press brake and gas at the same time to see if it is motor / transmission mounts but that is fine as well. Any idea as to what would cause this sound?
Jan 28, 2010 at 7:37 PM
  • 31,937 POSTS
Hi there,
Thank you for the donation,
This may be body noise, i would suggest that you get the Car on a hoist, back of all the front sub frame mounts and re tighten again, this may be sub frame movement under load, try this.
mark (mhpautos)
Jan 28, 2010 at 8:56 PM
SYED PIRZADA
  • 5 POSTS
Would sub frame movements cause clunking noises on turns as well. The noise is more pronounced at turns and less so on straight line acceleration. Can tie rod end or ball joint be a possibility?
Jan 29, 2010 at 3:04 AM
  • 31,937 POSTS
Hi there,
This is not common but re tensioning sub frame mounts is a standard job on all FWD cars during servicing, if yours has not been done, do it so we can eliminate that as a cause, tie rod ends wont do this, you can also try having the drive shaft nuts re tensioned as well, as i have had this type of nose in Toyota's,we just have to eliminate basics to start with.
mark
Jan 29, 2010 at 9:40 AM
SYED PIRZADA
  • 5 POSTS
Took the car for diagnoses to a local mechanic and he suspects its the Transmission mount. The noise only comes in Drive (D, D3 etc) on acceleration but there is no noise when car is accelerating in reverse. He says it is because in Drive the transmission is moving a lot but when in Reverse the 3 motor mounts don't let it move too far back. Does it make sense to you?
Jan 31, 2010 at 2:28 PM
  • 31,937 POSTS
Hi there,
if mounts at fault i would expect the noise to be there in rev as well, but if the mounts are faulty they should be replaced anyway.
mark (mhpautos)
Jan 31, 2010 at 7:29 PM
SYED PIRZADA
  • 5 POSTS
Passenger Side RH motor mount is bad. Also passenger side control arm is not put in properly and hitting against the edge.
I am confused though, why is the noise coming from the driver side. Is it normal to hear the sound from the other side ?
Feb 2, 2010 at 6:45 AM
  • 31,937 POSTS
Hi there,
with this problem as shown with the pics i would also expect that the noise would be more propionate from the affected side, noises can travel through the frame work and body and sound different from what you think, that is why we must look at all possibilities and not just presume that the problem is related to where we think the noise is coming from, when you fix these problems there still may be some noise from the drivers side as well, so it is important to have all suspension and mounts carefully inspected just to be sure,
mark (mhpautos)
Feb 2, 2010 at 7:25 AM
SYED PIRZADA
  • 5 POSTS
Had the lower control arm problem fixed will replace the the bad motor mount and re-tighten subframe mounts next. Thanks
Feb 2, 2010 at 9:15 AM
  • 31,937 POSTS
OK good idea, let me know how you get on.
Mark (mhpautos)
Feb 2, 2010 at 9:27 AM
