2003 Honda Accord Bent Piston
55,000 MILES • 4 CYL • FWD • AUTOMATIC
GIGSCOTT
Recently the car would not start - had to have it towed to Honda Dealer. They said there was diesel fuel in the gas tank and would have to empty and flush the lines and see if that would fix the problem. It did not and now they tell me there is a bent piston and the whole engine will have to be replaced! How would they know that the piston is bent? The car would crank, but just would not start. As far as the diesel fuel in tank, I can not imagine how this could have happened due to the nozzle not even fitting into the gas fill tube. What is your opinion?
Aug 8, 2008 at 3:25 AM
KHLOW2008
  • 41,812 POSTS
Hi gigscott,
You are right about the pump nozzle not of correct size. So if there really was diesel, you need to find out how it got there.
To test if con rods are bent, a compression test would be able to provide some insight.
Aug 9, 2008 at 8:26 PM
