1991 Honda Accord pistone
1991 HONDA ACCORD
DEE8SHORT
Brakes problem
1991 Honda Accord 4 cyl Front Wheel Drive Automatic
need to change the brakes but have a problem with the pistone have right tool but it seems to be siezed what do i do
Jul 20, 2008 at 6:09 AM
KHLOW2008
  • 41,814 POSTS
Hi dee8short,
When the front brake caliper pistons are stuck and difficult to move, they should be serviced or replaced.
Just pushing it back would cause the brakes to wear out prematurely and cause problems to the rotors.
Pump the pedal a little with 1 pc of pads removed to get the piston moving and lift up the dust cover to see if it is rusted inside. If the dust cover is torn, it should be replaced after sevicing or replacement of the piston.
Jul 21, 2008 at 10:23 AM
