2003 Honda Accord A/C cools passenger side, but not driver
2003 HONDA ACCORD
66,000 MILES • 4 CYL • 2WD • AUTOMATIC
RAFAEL0313
I have an EX Honda Accord (2003). I can control the temp of the A/C on my side and the passenger can control the temp on their own side. Lately, I have noticed that my side of the A/C is not cooling; I only get a small amount of cold air. However, the passenger side A/C works just fine. I recently changed the cabin air filter and the problem still persists. What could be causing this and how can I solve it?
Aug 26, 2009 at 2:27 PM
KHLOW2008
  • 41,814 POSTS
Hi rafael0313,
Problem is most probably caused by the air mix control motor.
You would have to check the linkage an try adjusting the heater control from max to cool a few times to see if the motor works.
Replacement of motor would be necessary if it does not work.
Jun 19, 2020 at 6:19 AM
