2002 Honda Accord Crank Sensor
2002 HONDA ACCORD
93,000 MILES • 4 CYL • 2WD • AUTOMATIC
JMULHOLLAND
Dear Sirs,
Recently (3-10-10) I had the timing belts water pump and front seals replace on my accord. While my wife was two states away it began to make a horrible noise and she was able to make it to a repair shop. They informed her that the "crank sensor" was not properly torqued and had failed.
If I understand correctly the crank sensor is important to determine TDC. But since the timing belts where all replaced would the previous mechanics be responsible for the proper placement and security of this part?
I know parts fail without warning, that is just mechanics, but will I have a leg to stand on if I go back to my mechanic and ask if he warranties his own labor?
Mar 29, 2010 at 7:47 AM
KHLOW2008
  • 41,814 POSTS
Hi jmulholland,
If it is proven that the sensor was not correctly torqued causing the problem, then yes, the previous mechaninc would be responsible for the problem.
During replacement of the timing belt the sensor was removed and correctly torqued when reinstalling.
Mar 30, 2010 at 7:00 AM
KHLOW2008
  • 41,814 POSTS
Hi jmulholland,
If it is proven that the sensor was not correctly torqued causing the problem, then yes, the previous mechanic would be responsible for the problem.
Mar 30, 2010 at 7:01 AM
KHLOW2008
  • 41,814 POSTS
Hi jmulholland,
During replacement of the timing belt the sensor was removed and not correctly torqued when reinstalling.
