1995 Honda Accord
MUFF09
  • 1995 HONDA ACCORD
Engine Performance problem
1995 Honda Accord 4 cyl Front Wheel Drive Manual
my 96 honda accord starts but whin I giv it gas it bak fires an shuts off I change the fuel pummp could it b the crank sensor but am get fire frum the coil back wat u thin is the problem help plz
Tuesday, April 21st, 2009 AT 6:25 PM
F4I_GUY
  • 3,302 POSTS
Check for proper fuel pressure with a pressure gauge.
Check for good strong spark that is white/blue at all cylinders.
Scan the ECU and retrieve any codes.
Let me know what you find.
Wednesday, April 22nd, 2009 AT 4:47 PM
MUFF09
  • 9 POSTS
GOT RIGHT FUEL PRESSURE RYT SPARK AN I BLOCK OFF THE EGR VALVE
Wednesday, April 22nd, 2009 AT 7:50 PM
F4I_GUY
  • 3,302 POSTS
Sorry can you re-phrase your reply? I do not understand.
Thursday, April 23rd, 2009 AT 5:09 PM
MUFF09
  • 9 POSTS
How cuold I tell if my crank sensor gone would my car still starts an stay idle for 20secs an shuts off
Friday, April 24th, 2009 AT 8:11 PM
F4I_GUY
  • 3,302 POSTS
The only thing remotely close to a crank sensor is the crankshaft position sensor inside the distributor. You will have no injector pulse and spark if these sensor is bad.
Do the checks I said in my first post and post up what fuel pressure you have and what codes are in the system.
Saturday, April 25th, 2009 AT 7:38 PM
MUFF09
  • 9 POSTS
I HAVE SCAN THE ECU CODES AN THE CRANK SENSOR CAME UP I ALREADY CHANGE IT AN NOW THE CYLINDER POSITION SENSOR IS SHOWING UP WAT IT IS AN HOW CAN I FIX IT
Sunday, April 26th, 2009 AT 8:25 PM
F4I_GUY
  • 3,302 POSTS
Replace the distributor.
Tuesday, April 28th, 2009 AT 6:28 PM
MUFF09
  • 9 POSTS
Thanks a milllion
Wednesday, April 29th, 2009 AT 5:22 AM
MUFF09
  • 9 POSTS
Howe do I reset my ecu
Thursday, April 30th, 2009 AT 4:40 PM
MUFF09
  • 9 POSTS
MY HEATED OXYGEN SENOR SHOWIN UP ON MY ECU CODE HOW CUD IT AFFECT MY CAR AN WHER IS IT LOCATED
Thursday, April 30th, 2009 AT 7:20 PM
F4I_GUY
  • 3,302 POSTS
Unhook the battery terminal for a minute or so.
Thursday, April 30th, 2009 AT 7:35 PM
MUFF09
  • 9 POSTS
Hey watz up my 96 honda accord was runin find den it shuts off by it self an now it wont start I try push starting it an it wont wrk but when I look underneath the car ther was alot a water on the ground by the water pump do u think my engine is lock up if not wat u think is the problem help please asap thanx
Monday, May 11th, 2009 AT 5:29 PM
