2002 Honda Accord
MARILYNYI
  • 2002 HONDA ACCORD
  • 6 CYL
  • FWD
  • 60,000 MILES
Was driving down the freeway, my car started to lose power so I pulled to the next exit, engine shut down could not start, had it towed home now the key will turn, not click, click like the engine wants to turn over, lights come on put can not get it to start just want a little information so maybe I can trouble shoot before I take it to a shop and get hosed.
Thanks Marilyn
Thursday, September 11th, 2008 AT 11:10 AM
KHLOW2008
  • 41,814 POSTS
Hi Marilyn,
You need to isolate the cause of the problem.
1. Check/test for sparks at plugs when cranking.
2. Remove air intake hose and pump some starting fluid into throttle body and try to start.
Test for fuel pressure at fuel rails.
3. Do a compression test if both the above don't work. It could be a broken timing beltà â â€
Sunday, September 14th, 2008 AT 9:19 AM
