2001 Honda Accord Popping Noise
LEESAMETRO
Drive Train Axles Bearings problem
2001 Honda Accord 4 cyl Front Wheel Drive Automatic 169k miles
Hi, I have popping noise in the front end of the car, It happens all the time, pulling out of the drive, turning, either way. It juat keeps popping/clicking more and more as time goes on. Any suggestions> I had a Taurus that had bushings changed that made a similar noise, and a Limina that had Rackon Pinion changed, with a similar noise. Please help!!!
Nov 5, 2008 at 5:14 AM
KHLOW2008
  • 41,812 POSTS
Hi leesametro,
Your description is not very clear and I can only make a guess as to the possible causes.
1. CV joints, this would be crocking like noise when making turns with slight acceleration.
2. Wheel not securely tightened.
3. CV shaft nut improperly torqued resulting in loose wheel bearing.
Nov 15, 2008 at 6:38 AM
