1996 Honda Accord Popping noise
HONDA96
Drive Train Axles Bearings problem
1996 Honda Accord 4 cyl Front Wheel Drive Automatic
sometimes when i put my car in reverse it makes a pop noise this doesnt happen all the time. But when my car down shifts to a stop it always makes a pop noise. This only started happening after my axles was replaced, we have taken off the passenger side axle and replaced it so far but the problem is still there. Do u think this noise is from the other axle r from something else?
Jan 5, 2009 at 4:07 AM
KHLOW2008
  • 41,812 POSTS
Hi honda96,
If it is a CV problem, the noise would not be intermittent. It would more likely be continous.
I would suspect a loose bolt somewhere on the lower frames or a faulty engine mount. Other possible cause would be trans internal fault.
Jan 10, 2009 at 2:27 AM
