2001 Honda Accord clutch
SSAWYER
  • 2001 HONDA ACCORD
  • 4 CYL
  • MANUAL
  • 150,000 MILES
My clutch pedal just goes to the floor and stays there, It doesn't engage the clutch
Saturday, November 7th, 2009 AT 8:41 PM
HONDA TECH 1818
  • 536 POSTS
Check the clutch master cylinder reservoir, it could be no more brake fliud due to the master cylinder leaking. Add brake fluid in the clutch master cylinder reservoir and bleed the clutch master.
Sunday, November 8th, 2009 AT 12:46 AM
  • 31,937 POSTS
Hi there,
Check the clutch fluid, I feel that it will be low or, if so check under the dash where the clutch pedal push rod is for fluid and also under the rubber boot of the slave cylinder on the gearbox, fluid will indicate leaking and air has entered the system, you may be able to top it up and pump the pedal a few times to get a clutch pedal so you can go get this fixed.
Mark (mhpautos)
Sunday, November 8th, 2009 AT 12:50 AM
