I have been noticing while I am driving & in gar and go to accelerate the engine revs & the tachometer flies but I am not accelerating. Only when I back off the gas
and accelerate smoothly do I get power. Any hard acceleration I get the problem.
What would cause this?
SPONSORED LINKS
Thursday, February 18th, 2010 AT 12:16 PM
MECHANIC
Sounds like your clutch is slipping
Thursday, February 18th, 2010 AT 12:21 PM
STIMPY63
MEMBER
It could slip even though I am already in gear?
SPONSORED LINKS
Thursday, February 18th, 2010 AT 12:26 PM
MECHANIC
Going down the road and you decides to make a jack rabbit move and the rpm goes up but the car is not moving as expected.
Thursday, February 18th, 2010 AT 12:29 PM
STIMPY63
MEMBER
Thats correct. Shifting gears is fine & if I accelerate smoothly I am good, but when I want that punch of power, thats what happens.
Thursday, February 18th, 2010 AT 12:57 PM
MECHANIC
Replace the clutch assy-that means pilot bearing, clutch disc, clutch cover and release bearing-Good luck
