My Car is making me worried.\R\nWhenever I start moving after red lights, my car engine roar very hard, up to 4000 r/min, to get to the normal speed.
Is there any problem with my car and how can I fix it?
Saturday, June 19th, 2010 AT 8:39 PM
MECHANIC
Does it idle fast or is this as a result of touching the throttle, I am just trying to visualize your problem.
Mark (mhpautos)
SPONSORED LINKS
Saturday, June 19th, 2010 AT 8:43 PM
BAOHO
MEMBER
I am not sure, but whenever I push the pedal for the car to go, the engine roar. If I push it normally, my car will slowly to go. If I try to push it harder, it start to roar up to 4000 r/min
Sunday, June 20th, 2010 AT 6:10 PM
MECHANIC
Check that your transmission fluid level is correct and that you have no leaks.
Mark (mhpautos)
Sunday, June 20th, 2010 AT 10:28 PM
BAOHO
MEMBER
Thanks for your advice, I will do it.
And one more thing, is that OK if I go at D3 at the beginning and then change to D4 when the car get to normal speed? Is my car engine still good overtime?
Monday, June 21st, 2010 AT 11:15 AM
MECHANIC
D4 should manually select over drive,
mark (mhpautos)
SPONSORED LINKS
Monday, June 21st, 2010 AT 5:14 PM
BAOHO
MEMBER
So that mean I should not put D3 at the begining and then change to D4?
