1999 Honda Accord V-6
RPOEHLING
  • 1999 HONDA ACCORD
There is a high pitch noise that accompanies the ordinary engine noise. When the rpm's are increased, the pitch of the new noise gets higher. When the rpm's are decreased, the pitch of the new noise gets lower. What's going on here and is the car safe to drive?
Monday, May 7th, 2007 AT 8:16 PM
PARISHERJ
  • 11 POSTS
Sounds like you might have a vaccum leak somewhere. Check the main vaccum lines for leaks. Like the brake booster and pvc. Does it do it sitting in park or only under a load in gear?
Monday, May 7th, 2007 AT 9:09 PM
RPOEHLING
It does is in both park and when in gear.
Monday, May 7th, 2007 AT 9:27 PM
PARISHERJ
  • 11 POSTS
Well if it does it while in park it rules out the trans. I have a ford that does that but only in gear. I'd start with the vaccum lines.
Monday, May 7th, 2007 AT 9:39 PM
RPOEHLING
Since I couldn't diagnose the problem myself, I took the car to the shop. Turns out, the noise was coming from the alternator.$550 later, I'm back on the street with a quiet car.
Thnks for your help.
Thursday, May 10th, 2007 AT 8:52 AM
