I was going to try the fuel regulator thing you said in a couple days when I had time. Another symptom came up that may be part of it.
I hear a rattling under the car that sounds just like a heat shield on a cat convertor. I took the heat shield off and it sounds like the rattling is inside the cat convert. When I gave it gas to get it to start up (old problem) lots of smoke came out of the muffler.
Could a bad CAT convert. Cause car not to start unless I give it gas?
Thanks.
When I solve this I will send another donation
PS I check heat shield under hood. The sound is in cat convert. Or the s pipe
SPONSORED LINKS
Tuesday, March 9th, 2010 AT 7:16 PM
