change the rotors but theirs 2 screws in the middle of the rotors that wont come off
TISOY69
i'd like to change the rotors but theirs 2 screws in the middle of the rotors that wont come off. can you pls. tell what to do. thanks
Mar 8, 2008 at 11:19 AM
SQM
  • 6,383 POSTS
Those two screws in the middle are there to keep the rotor in place during the assembly process and they are not needed.
These screws can be seized on the hub. Use penetrating oil and spray liberally on them and try to remove them again.
If you are just not able to remove them and the head is stripped, then you will have to drill out the screws.
Here is a helpful video of how to drill out bolts:
https://youtu.be/YDt5OUIZTs0
https://www.2carpros.com/articles/how-to-replace-front-brake-pads-and-rotors-fwd
Oct 20, 2021 at 7:53 AM
