1998 Honda Accord replacing Front rotors
201,000 MILES • 4 CYL • FWD • AUTOMATIC
IBMSHARK
I have a 1998 Honda accord with disk brakes .can you tell me the steps required to replace my front rotors and if any special tools are required. I have replaced the brake pads many times so I think I can manage this also
Regards Harry
Mar 15, 2010 at 6:29 AM
MERLIN2021
  • 17,250 POSTS
Removal & Installation (Except 1997 Accord) 1. Raise and support vehicle. Remove wheels. Remove caliper assembly, and suspend it using wire. See FRONT BRAKE CALIPER. Attach dial indicator to caliper mount .39" (10.0 mm) from disc outer edge. Check disc runout before removal. See DISC BRAKE SPECIFICATIONS table. 2. Detach and remove two 6-mm disc retaining screws. Install two 8 x 1.25 x 12-mm bolts in existing holes. To prevent warpage, alternately turn bolts 2 turns at a time until disc can be removed from hub. 3. Clean disc of all rust, and inspect disc surfaces for cracks and grooves. Resurface or replace disc as necessary. To install, reverse removal procedure. Tighten retaining screws. Bleed hydraulic system (if necessary). See BLEEDING BRAKE SYSTEM . Page 1 of 1 3/15/2010 http://www.ondemand5.com/mric/common/asp/Article.aspx?MOD=REPART&YEAR=19 ...
Mar 15, 2010 at 7:30 AM
IBMSHARK
do you have any pictures that illusrate the paragraph below : so I know where to look for the screws?
Mar 15, 2010 at 11:49 AM
MERLIN2021
  • 17,250 POSTS
I dont, but take the tire off and you will see two philip screws on the hub part of the rotor. If they arent there, it means a brake job was done before, and they werent replaced.
Mar 17, 2010 at 7:09 AM
