1999 Honda Accord front right steering rod boot ( bearing c
89,000 MILES • 6 CYL • FWD • AUTOMATIC
HELEN TAVITA
the front passenger side boot or steering rod cover is busted on the honda accord, how do i change it?
updated 5/18/09
Thank you so much for your advice... If i want to replace the parts myself do I Need special tools to do it?
May 16, 2009 at 3:43 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:d29ef15c0e="helen tavita"]Steering problem
1999 Honda Accord 6 cyl Front Wheel Drive Automatic 89000 miles
the front passenger side boot or steering rod cover is busted on the honda accord, how do i change it?[/quote:d29ef15c0e]
Hi Helen,
Lets make sure of what you are speaking of.
The boot is it right behind the wheel and look like it is going into the wheel? If so you would be better off replacing the CV Axle and not just the boot. Why you are asking, well because depending on how long it has been busted, road debri and other contaminates have gotten inside and has started wearing the CV Joint components and failure could happen within the next month or so. So, to just replace the boot will be a waste of time.
May 16, 2009 at 4:10 AM
OBXAUTOMEDIC
  • 3,711 POSTS
You will need a Floor Jack or the jack that came with the car. A good set of Jack Stands to stabilize the car.
Other Tools You'll Need:
Set of 3/8-inch drive sockets Ratchet ½-inch drive 36 mm socket, Ball joint separator Hammer Pry bar Set of metric wrenches.
Changing a CV Axle can be tough if you've never done one.
Instructions
Step 1 Jack the vehicle up and support it on jack stands. Remove the both front wheels. Using the 36 mm socket, remove the center axle nut. Remove the though-bolt on the bottom of the strut where it attaches to the spindle.
Step 2 Separate the bottom ball joint from the spindle using the ball joint separator. Using the pry bar, pry the lower control arm down to pull the separated ball joint out of the spindle and push the spindle out of the way toward the rear of the car.
Step 3 Use the pry bar to pry the CV axle out of the transaxle. Put the pry bar between the transaxle case and the CV axle, and push it out. Remove the CV axle and put it in the box the new axle came in---CV axles carry a core fee, which is refundable upon return of the old axle.
Step 4 Install the new CV axle by inserting it into the transaxle up to the snap ring clip where it will stop. With both hands, pull it back about an inch and slam it in with a fast push, and you will feel it snap into the locked position.
Step 5 Grab the brake rotor, pull it outward and insert the outer end of the CV axle into the hub in the rotor. Rotate the rotor back and forth to line up the splines and push the axle in as far as possible. Loosely screw on the axle nut.
Step 6 Pull the lower control arm down with the pry bar. Line the ball joint up with the hole in the spindle and insert the ball joint. Install the nut on top of the ball joint and tighten it down.
Step 7 Install the bolt in the bottom of the strut where it attaches to the spindle and tighten. Torque the axle nut to 180 foot pounds. Put the wheel on and repeat from Step 1 for the other side.
Add the www to the site below for an example if a CV Axle being replaced...
May 18, 2009 at 4:00 PM
