I have a 1999 Honda Accord LX with 120000 mi. It runs fine when cold, but when its warmed up and you come to a stop the rpms drop and the engine struggles to stay on sometimes resulting in a stall. I went to the autoparts store and looked up the code which was p1166, p1167 (maufacturer control fuel/air monitoring). The common fix as per Haynes was to replace the O2 sensor. Did that nothing has changed. The car also hesitates when you take your foot off the brake and then press the accelerator, placing from park to drive, neutral reverse.
SPONSORED LINKS
Tuesday, March 4th, 2008 AT 3:38 PM
