1999 Honda Accord Loses Power
WHEELSUCKER
We're having bitter cold weather here in chicago and my car was running okay, but then when I got on the highway it just lost power. It revs when the gas pedal is pressed and it starts just fine, but I cannot get it above 15 MPH and it finally died.
We put in heet in case it was a fuel line freeze up, but that did not help. My wife said the exhaust smelled "Rich".
It's a manual trans so I know it's not the tranny.
Any suggestions?
Feb 5, 2007 at 11:04 AM
BRUCE HUNT
  • 3,754 POSTS
Have you moded the air intake? Is the air filter clean and original in type. Lack of air or freeze up can restrict the air flow and act this way. The fuel line is yet another and the heet may not have reached the problem. Check this out and reply.
Feb 6, 2007 at 1:36 AM
WHEELSUCKER
The air filter is clean as I just had the oil changed two weeks ago...and yes, I did check it out.
No I have not modified the air intake at all.
The funny thing is, it starts, the engine revs without sputters and it idles just fine. It just doesn't go anywhere. My wife thinks maybe an O2 sensor went and it's running really rich. She says either that or the clutch!
Feb 6, 2007 at 4:58 AM
BRUCE HUNT
  • 3,754 POSTS
Check engine light on at all? During the time when the car will not move does it feel like the brake is on? Does a brake get hot? Does it feel like something is dragging the car down?
Feb 6, 2007 at 11:01 PM
WHEELSUCKER
I think the check engine light came on when it died. No brakes do not get hot and the emergency brake is not on.
Feb 6, 2007 at 11:11 PM
BRUCE HUNT
  • 3,754 POSTS
Help yourself and us, get the code from the computer.
Feb 7, 2007 at 1:47 AM
Suggested Repair
Retrieve the stored check engine code and diagnose from it. Also verify the air filter and intake are not restricting airflow, and consider fuel delivery or a rich-running condition if the code points that way.
Conversation Summary
A 1999 Honda Accord with 169,000 miles lost power in bitter cold, would not exceed about 15 mph, and then died, though it started and idled normally and revved without sputtering. Heet did not help, the air filter was clean, and the intake was unmodified. The exhaust smelled rich, the check engine light came on when it died, and the brakes were not dragging. The expert advised retrieving the computer code.
