1999 Honda Accord
WILL821
  • 1999 HONDA ACCORD
  • 4 CYL
  • 185,000 MILES
Please show w/ diagram, how to replace front lug studs
Tuesday, October 28th, 2008 AT 4:16 PM
KHLOW2008
  • 41,814 POSTS
Hi will821,
Sorry to say that no such diagrams are available as this is a normal mechanical repair job.
You need to release the CV joint main nut, remove the brake calipers with mount and brake rotor. The hub then has to be pulled out slightly to enable enough clearance for the studs to be removed by knocking them out.
Tuesday, November 11th, 2008 AT 7:45 AM
