1989 Honda Accord CV Boot
140,000 MILES • 4 CYL • FWD • AUTOMATIC
MINDCRIMEV3
My cv boot is split on the front passenger side of my car. There is grease all over the inside of the tire and on the brakes. I've purchased a quick boot kit to put on but the tire won't come off. I've removed all 4 lug nuts but the tire seems stuck on and I've tried really hard to pull it off. Have you ever heard of this and do you have a suggestion for a solution? I would really appreciate any help I could get with this to avoid having to take it to a shop and pay a lot of money.
Thanks,
Isaac
Feb 9, 2008 at 12:14 PM
  • 31,937 POSTS
Hi there,
You will have to give the tyre a decent belt from behind, leave a nut on loose just in case, If still stuck replace all nuts, not tight jack car down, & turn steering lock to lock, this should free up the rim on the hub.
mark (mhpautos)
Feb 9, 2008 at 3:50 PM
