1998 Honda Accord HESITATION
KILLIANAUTO
  • 1998 HONDA ACCORD
Engine Performance problem
1998 Honda Accord 6 cyl Front Wheel Drive Automatic
WHEN I PRESS ON THE GAS THE CAR HESITATES AND THEN STARTES TO MOVE. WHAT COULD BE THE PROBLEM
Friday, February 12th, 2010 AT 1:30 PM
Inspect and test all the following below:
Oxygen sensor
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Friday, February 12th, 2010 AT 1:41 PM
