1998 Honda Accord Clutch rleases
79,000 MILES • 4 CYL • FWD • MANUAL
RAWERLEY
When sitting at stop with brake and clutch pedal pressed, such as at stop sign, the clutch will slowly engage after a 15-20 second period even though it is still fully pressed to the floor. The same if you are in neutral. After the same amount of time you can't get car into gear unless you release clutch and press again to re-engage. The clutch fluid level is normal and there are no apparent leaks that would cause the loss in clutch pressure.
Apr 29, 2008 at 7:57 AM
BUZZSAW
  • 1,198 POSTS
[quote:547fbeac56="rawley"]Transmission problem
1998 Honda Accord 4 cyl Front Wheel Drive Manual 79000 miles
When sitting at stop with brake and clutch pedal pressed, such as at stop sign, the clutch will slowly engage after a 15-20 second period even though it is still fully pressed to the floor. The same if you are in neutral. After the same amount of time you can't get car into gear unless you release clutch and press again to re-engage. The clutch fluid level is normal and there are no apparent leaks that would cause the loss in clutch pressure.[/quote:547fbeac56]
the clutch cylinder could have an internal leak that keeps the fluid in it still
Apr 29, 2008 at 8:49 AM
