1993 Honda Accord clutch
1993 HONDA ACCORD
212,000 MILES • 4 CYL • 2WD • MANUAL
MRNEELEY
ok i made a mistake my car is a 93 not 97 why i thought that i dunno. anyway i changed and put in new break fluid but the clutch is now on the floor and will not go into any gear.. what could it be now
Jun 8, 2008 at 12:10 PM
KHLOW2008
  • 41,814 POSTS
Hi mrneeley,
If you did any repairs to the clutch hydraulics, you need to bleed the system.
If there is nothing wrong with the master or slave cylinder just lift the pedal up and pump by hand, lifting where necessary.
The pedal has a self pushing spring which would hold the pedal down if it is more than 1/2 way down. Just lift the pedal up.
Jun 9, 2008 at 1:00 AM
