Hi HondaBoss,
There are a few possibilities.
1 The clutch master cylinder or slave cylinder is weak resulting in insufficient clutch travel.
2. Clutch master cylinder push rod not properly adjusted.
3. The clutch disc is faulty, might be dislodged dampers causing it not to release fully when clutch is depressed.
Check the hydraulics, first, if no faults fould, the clutch assy needs to be checked.
SPONSORED LINKS
Monday, October 20th, 2008 AT 12:24 PM
