Remove the exhaust manifold downpipe.
Drain the oil from the pan, remove all the oil pan bolts and the flywheel cover. Once all the bolts are removed the pan should drop if you give it a firm tap with a soft faced hammer.
Make sure to clean all the old gasket and silicone off the mating surfaces.
SPONSORED LINKS
Thursday, March 19th, 2009 AT 5:46 PM
