1998 Honda Accord
CHRISMISTER2K1
  • 1998 HONDA ACCORD
1998 Honda Accord 6 cyl
how do you bleed the cooling system in a 98 honda accord v6
Sunday, December 7th, 2008 AT 1:29 PM
KHLOW2008
  • 41,814 POSTS
Hi chrismister2k1,
Bleeding cooling system
1. Pour Honda All Season Antifreeze/Coolant Type 2 into the radiator up to the base of the filler neck.
NOTE:
Always use Honda All Season Antifreeze/Coolant Type 2. Using a non-Honda coolant can result in corrosion, causing the cooling system to malfunction or fail.
Honda All Season Antifreeze/Coolant Type 2 is a mixture of 50% antifreeze and 50% water. Pre-mixing is not required.
Engine Coolant Refill Capacity [including the reservoir capacity of 0.6 L (0.6 US qt, 0.5 Imp qt): 5.6 L (5.9 US qt, 4.9 Imp qt)
2. Install the radiator cap loosely.
3. Start the engine and let it run until it warms up (the radiator fan comes on at least twice).
4. Turn off the engine. Check the level in the radiator, and add Honda All Season. Antifreeze/Coolant Type 2 if needed.
5. Put the radiator cap on tightly, then run the engine again and check for leaks.
Monday, December 8th, 2008 AT 6:59 AM
