1998 Honda Accord COOLING FAN NOT RUNNING WHEN ENGINE IS RU
150,000 MILES • 4 CYL • 2WD • AUTOMATIC
SONNYVO
I noticed that the cooling fans are not running when the engine is running. As soon as I turn the engine off that is when the fan start running... what is the problem or problems
Oct 30, 2008 at 4:37 AM
KHLOW2008
  • 41,812 POSTS
Hi sonnyvo,
The cooling fans operate only when the temp is more than the preset of the fan switch sensor. If they don't work when the gauge is showing overheating, you need to check the fan switch located on the thermostat housing.
The fans should work with the AC turned on.
There is a cooling fan switch located at upper hose outlet and when ignition switch is turned off, if the temp is more than the preset of the switch, the fans would be turned on to col the engine down. It should not work more than a few minutes.
You should check the coolant level in the radiator, insufficient coolant would cause what you described.
Nov 1, 2008 at 5:57 PM
