1998 Honda Accord Oil in Coolant
I did check the automatic transmission coolant line and it was o.k. Now I don't know whether to do another tear down and have the head resurfaced or what!! What do you think?
Actually, the oil is in the coolant. Does this make a difference? If I need to have a pressure check, do I have to take the head to a garage to have that done?
Thanks for the advice. I'll let you know how I make out.
Suggested Repair
Remove the cylinder head and have a machine shop pressure-check it for cracks and check warpage, then resurface it if needed. Install a new head gasket. The transmission cooler line was already checked and found okay; if the head checks out, a cracked block remains possible.
Conversation Summary
A 1998 Honda Accord with about 109,000 miles overheated and had oil in the coolant. Two mechanics suspected a head gasket. The owner replaced it with an aftermarket gasket and did not resurface the head because measured warpage was within 0.002 inch, but oil returned to the coolant on a smaller scale. The owner confirmed the automatic transmission cooler line was okay. Experts advised removing the head for crack and warpage checks and installing a new gasket, noting a cracked head or block if those checks pass.
