1997 Honda Accord Door Lock Actuator
136,000 MILES • 4 CYL • FWD • AUTOMATIC
REXFITCH
How do I install a right rear side door lock actuator? Your assistance is greatly appreciated.
Jun 23, 2010 at 11:56 AM
JEREMIAH
  • 217 POSTS
you need to remove the door panel, 2 screws behind the handle's cover 1 screw in the pocket. unplug the actuator, release the latches and cables, unscrew the latch assembly from its side with a #3 phillips, pull the latch assembly out and replace the actuator.make sure to have the window up before you begin.
1st time and no instruction? give yourself 2 hours of free time to be on the safe side,though it would take me 10 minutes.
Jun 24, 2010 at 11:46 AM
