1996 Honda Accord Warm air/Idle/Acceleration
207,500 MILES • 4 CYL • FWD • MANUAL
JBUONOCORE
When my air is set to vent from the outside with the AC off, warm air is produced even though the outside air is much cooler. I have replaced the thermostat and coolant but the problem still exists. Any suggestions?
I also have a problem with idle and acceleration. The idle is missing and the acceleration seems like i am only under 3 cylinders of power. I have had a tune up, replaced plugs, wires, distributor, check timing, etc. The dealer cleaned the idle body and idle screw and the problem went away. However, that only lasted 2 months and the problems returned. At a cost of $200, I do not want to keep paying this over and over. Any suggestions?
Apr 11, 2008 at 12:28 AM
BRUCE HUNT
  • 3,754 POSTS
heat and cold air mix in the plenum. There is a damper that lets in hot air and closes of the hot air. i would say that the door is not working and is stuck part way.
on the engine miss are you getting a check engine light? The fuel economy of the vehicle must be terrible.
if you pull the plugs one at a time they may indicate which cylinder is not performing to the best of its ability. The issue could be your EGR valve or an injector.
Apr 11, 2008 at 3:40 AM
JBUONOCORE
Thanks for the prompt response.
As far as the plenum, can i access that? If so, is this something i can try and fix?
As far as the idle, no check engine light illuminated. The mph has decreased from 33-35 to 28. With gas prices going up, this is now noticeable in the pocket!
Apr 11, 2008 at 4:30 AM
BRUCE HUNT
  • 3,754 POSTS
I have a diagram of the heater system and there is a very good chance that this is beyond most do it yourselfers. Now if you still wish to pursue this on your own I can send you some materials via email. Let me know.
Apr 14, 2008 at 5:45 AM
