1996 Honda Accord Leckage of radiator & over heating
171,740 MILES • 4 CYL • FWD • MANUAL
NEHAL
  • 7 POSTS
well i must say u r doin a great job. realy don,t have words to explain.
will you be kind enough to tell me that if i gona replace the head gasket on some one who knows the job ! but as that gona creat any effect on my engine efficiency as i neva open it before ??? 2nd my rediator as also some leakage? do i need to change it completly or should be repair ?? the rediator heated up twice badly ?? do i need to travel in the same situation ??
May 27, 2008 at 5:34 PM
  • 31,937 POSTS
Hi there,
I would start with getting the radiator repaired, and replace the thermostat and the radiator cap as well. make sure the cooling fans are working, and have the system pressure tested for leaks. If you are still experiencing over heating problems. you will have to get the engine checked for a head problem, but get the cooling system sorted out first.
mark (mhpautos)
May 27, 2008 at 5:40 PM
