First check the fuse for the horn. If that does not solve the problem the horn is located generally up front around the radiator. You can test to see if the horn works by running a test wire from the battery to the horn. The horn can also be plugged with dirt not allowing it to vibrate.
SPONSORED LINKS
Sunday, December 7th, 2008 AT 8:30 PM
