1995 Honda Accord Intermittent starting
MIKEHOW148
  • 1995 HONDA ACCORD
  • 4 CYL
  • FWD
  • MANUAL
  • 165,000 MILES
Battery has 12V everything electrical works, except it seems to start without jumping when it wants, I changed the Main Relay and the problem is still there. As stated it will start with jumper cables are jump box. The last load test done on the battey several months ago was good, but I am going to have it done again. When it won't start it also will not crank, except with a jump.
Wednesday, June 9th, 2010 AT 7:25 PM
F4I_GUY
  • 3,302 POSTS
If it only starts with a booster back or a jump on it, that means the battery has been run down.
Check your alternator output, it may not be charging the battery and test for parasitic draws (draws that drain the battery with the key off).
Thursday, June 10th, 2010 AT 4:31 PM
MIKEHOW148
When the car is running there is 14V at the battery. The car starts fine after sitting a while (a couple of hours/overnight), and it never shuts off or stops while driving. The load test on the battery showed the battery as being good. When it won't start it does not crank or attempt to crank, interior lights dim but no more then what they do when it starts.
Thursday, June 10th, 2010 AT 9:26 PM
