1995 Honda Accord 95 Accord electrical
CEYRON
  • 1995 HONDA ACCORD
  • 4 CYL
  • FWD
  • 45,000 MILES
Hi I recently wrote about my 95 accord, how the battery was charged but crossed the wires and the car died completly. I put in a new battery and alternator but still the battery dies. The response I got was to replace the fusable link from the alternator back to the battery. Im not sure but I replaced the 80 amp fusable link in the dash under the hood. Is there another fusable link besides that and if so where is it located I only found one and all the other fuses are fine. Thank You
Monday, February 9th, 2009 AT 4:47 PM
KHLOW2008
  • 41,814 POSTS
Hi Ceyron,
You should have replied back to the same thread so that whoever was attending to you can get back to you as soon as notification is received.
The history of the question and replies would be easier to follow through.
When engine is running, test for charging voltage at alternator and battery terminals separately to see if the charging rate is within 13.5 to 14.5 volts.
Is the charge warning indicator lamp working correctly?
Wednesday, February 18th, 2009 AT 3:21 PM
