Hi there,
Working with the engine cold, first remove the heat shield on the exhaust manifold, and from under the car undo the flange (manifold to engine pipe bolts) if there is an O2 sensor fitted to the manifold remove next, undo the 8 manifold bolts and the support bracket if fitted, the manifold will now come off.
Mark (mhpautos)
SPONSORED LINKS
Tuesday, August 26th, 2008 AT 5:19 PM
