Thanks for your time and effort for my questions. Appreciate your useful solutions.
1995 Honda Accord Slow Warmup
Suggested Repair
Use a factory timing belt. Check the thermostat and replace it with the factory temperature rating if it is stuck partially open. Inspect for a heater-core coolant leak if heat produces a stale smell. Drive gently rather than idling for a long warmup. Avoid performance additives; little extra power is available beyond the stock design.
Conversation Summary
The owner of a 1995 Honda Accord asked about timing-belt brand, a long high-idle warmup, 15-inch tires, a stale smell on heat, fuel additives, and slow acceleration. Experts recommended factory parts, checking the thermostat, and inspecting for a possible heater-core leak that could affect the coolant temperature sensor. They said a long idle warmup is unnecessary if the car is driven gently, and that little can be done to add power beyond the stock design.
