1994 Honda Accord Speedometer/Odometer problem
182,000 MILES • 4 CYL • FWD • AUTOMATIC
MSP9745
My speedometer often is stuck at 20 mph. When I first step on the gas it will try to fluctuate up a tad bit but it still sits around 20. As long as this is going on, the odometer does not run either. Every few days, the speedometer will simply shoot up to the proper speed and start working and the odometer follows and works also. But this is short lived as the speedometer soon is stuck at 20 again. Note: it never gets stuck at 0...only at 20??? What could be my problem and how could I perform diagnostic tests to pin point the problem???
Thank you,
Jul 31, 2008 at 8:30 AM
KHLOW2008
  • 41,812 POSTS
Hi msp9745,
Thank you for your donations.
Your symptom points to a faulty speed sensor. The item is located below the thermostat housing bolted on top of the trans meter gear unit.
At times the D4 light will blink when driving and CEL shows?
Bridging the SCS connector behind the glove compartment should provide some answer to the error code.
Jul 31, 2008 at 12:17 PM
