1994 Honda Accord oil in spark plug
PENGUIN6094
Engine Mechanical problem
1994 Honda Accord 4 cyl Two Wheel Drive 234456 miles
I was having my spark plug changed and when he pulled out that wire attached to the spark plug there was oil in there. I also had to replace the pvc valve. Why is there oil in there. What do I need to check or do
May 30, 2009 at 2:57 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:5fd0e201f6="penguin6094"]Engine Mechanical problem
I was having my spark plug changed and when he pulled out that wire attached to the spark plug there was oil in there. I also had to replace the pvc valve. Why is there oil in there. What do I need to check or do[/quote:5fd0e201f6]
You will need to replace the Valve Cove Gasket. The seal around the plug hole are leaking thats why there is oil in the spark plug hole.
May 30, 2009 at 3:51 PM
