1994 Honda Accord clutch
MARKUSF22B
  • 1994 HONDA ACCORD
  • 4 CYL
  • FWD
  • MANUAL
  • 192,000 MILES
I was driving and came to a stop and could not put my car in gear because the clutch pedal has no pressure, it just stays down and it is impossible to change gear some people have suggested I need a new clutch kit while other think it might be a leak but most people think it is the clutch cable. Does anyone know what I need to get fixed?
Wednesday, June 3rd, 2009 AT 3:59 AM
  • 31,937 POSTS
Hi there,
Check for a leaking clutch master cylinder or slave cylinder, peel the rubber boot back on the slave and see if fluid leaks out, check under the dash where the clutch pedal is and look for fluid leaking from the rear off the master cylinder, start here.
Mark (mhpautos)
Wednesday, June 3rd, 2009 AT 7:18 AM
