1994 Honda Accord Floppy Clutch Pedal
150,000 MILES • 4 CYL • FWD • MANUAL
PAUSHAUN
My clutch pedal does not have any resistance. The last time this happened, the mechanic bled the air frim the clutch line and it worked.
Were is the bleed screw located? How do I bleed the clutch line?
Mar 31, 2008 at 4:58 PM
BRUCE HUNT
  • 3,754 POSTS
Bleeder is usually located down by the tranny. The bleeder is usually a #8 wrench. The process is best worked on with two people. One pushes on the pedal while the bleeder is cracked open and while the pedal is down close the bleeder and pull the pedal up. Repeat until no air comes out with the fluid.
Now the big question is really, how does air get in to a closed system? LEAK The leak can be in the master cylinder, the slave cylinder, or the line between. Find the problem!
Apr 1, 2008 at 9:53 AM
