1994 Honda Accord Brake Lights
BIGCG
  • 1994 HONDA ACCORD
Brakes problem
1994 Honda Accord Front Wheel Drive Automatic
Brake lights have stopped working. Replaced the Brake switch and checked all of the bulbs. They all seem to be in good order. Any suggestions?
Tuesday, January 27th, 2009 AT 9:36 PM
  • 31,937 POSTS
Hi there,
You will have to check the power flow. Is there power at the switch and through the switch when pedal pressed? Is there power at the brake light globe socket if so check the earths and if no power check the fuse, start here.
Mark (mhpautos)
Tuesday, January 27th, 2009 AT 10:07 PM
BIGCG
Thank you. I went to an auto parts store and was asking some questions and was told that there is a module at the rear brake light and that might be the problem but to also check the wiring. Thank you again. Carl
Friday, January 30th, 2009 AT 4:50 PM
