Can hitting a pothole bend the rear subframe or push the steering rack back?
Friday, January 9th, 2009 AT 6:51 PM
BMRFIXIT
MECHANIC
If the hole big enough yes I would check the rim 1st
and if you had it towed its very common for the tow gay to place the hold down around the links and that practice will bend the links
SPONSORED LINKS
Friday, January 9th, 2009 AT 9:10 PM
LTURNER1978
MEMBER
Can the steering rack be pushed back and and the subframe be bend for a few months with no problem? I dont recall hitting any curbs or bigger than normal potholes and my car dealer said I did the damage there's no way it was already there. I've had the car for a couple months and over time the alignment has been getting worse and I had to replace the ball joint and split boot about a month a go and now there tellin me the whole a-frame is bent. (What is that?) Basically, I dont think anything I did caused the damage. I think it was already there. Can you give me your thoughts?
Saturday, January 10th, 2009 AT 7:02 AM
BMRFIXIT
MECHANIC
Friend u need a local help u have to take the car to a different place and let them inspect it for u
as I see it if you hit something to cause that kind of damage u would felt it for sure
get another opinion
Saturday, January 10th, 2009 AT 1:57 PM
LTURNER1978
MEMBER
Thanks for your help!
Saturday, January 10th, 2009 AT 2:01 PM
BMRFIXIT
MECHANIC
Good luck
try and ask around for a good and trusty locale shop
and let them check it for u
