1993 Honda Accord 2nd Gear Grinds
Suggested Repair
Check whether the clutch is cable-operated and adjust the cable if needed, and verify the gear lubricant level. Warm-only grinding into 2nd gear may indicate a failing synchronizer; pausing briefly after the clutch is fully disengaged may reduce the grinding.
Conversation Summary
A 1993 Honda Accord with a 5-speed manual grinds when shifting into 2nd gear after about 30 minutes of driving, from either 1st or 3rd, and only once the transmission is warm. A mechanic found nothing. One expert suggested checking for a cable clutch that may be out of adjustment as parts expand with heat. Another suspected a failing synchronizer, advised confirming the gear lube level, and asked whether waiting a couple of extra seconds after the clutch is engaged reduces the grinding.
