1993 Honda Accord What is acceptable play in Tranny?
1993 HONDA ACCORD
359,000 MILES • 4 CYL • 2WD • AUTOMATIC
TOMINNC
  • 7 POSTS
I noticed that when driving along at 60mph with cruise on it seemed like car would hesitate occasionally. The rpm's were not dropping or revving up but it would hesitate. I was doing brakes today and noticed when I put wheel back on I had about an inch of movement. I had axles replaced a few years back so I was wondering if it could be something where the splines go into the tranny? The tranny shifts throughout the gears fine and does fine whenever you are accelerating. I have never had anything done to the tranny so I guess I am due. I am going to check around to see about getting it rebuilt but wanted to check here to see if I am on the right path. Car runs excellent just got this problem. Wanting to see if I can hit 500,000 miles.
Thanks,
Tom
May 12, 2010 at 12:35 PM
  • 31,937 POSTS
Hi there,
What you are feeling is a bit of back lash inn the differential gears, this is normal, but i would go get the transmission serviced as a matter of course as this will help you keep on the road with out any transmission problems.
mark (mhpautos)
May 12, 2010 at 3:39 PM
TOMINNC
  • 7 POSTS
Thanks, will do that.
May 13, 2010 at 10:19 AM
