1993 Honda Accord 4 cyl Front Wheel Drive Automatic
after reviewing reasons why it shuts off while driving I checked the spark plugs and #2 cylinder had 2-3 tablespoons of oil on top side of plug, #3 cylinder had 1 teaspoon of oil on top side of plug. I realize the plugs and wires need to be replaced because of this. Though I don't understand why they have oil. I replaced the wires, plugs, cap, rotor, fuel filter, valve cover gasket, 4 spark plug tube seals, timing belt, counter shaft belt, water pump, ignition coil, main relay and alternator belt because #2 cylinder had oil before. Do you have any idea why this is happening again? And is this the only cause for it shutting off while driving? It shuts off once every 2 months and starts up in an hours time.
SPONSORED LINKS
Monday, July 14th, 2008 AT 8:43 PM
