1993 Honda Accord Car stalls after start up/ shuts down on
GOBLETTE01
  • 1993 HONDA ACCORD
  • 4 CYL
  • FWD
  • 78,800 MILES
I have replaced the ignition module and the coil two times the last four years to allieviate this problem. I did the last ignition replacement in April 08. 1/2/09 the car is doing it again. (Sometime starts, sometimes doesn't, sometimes shuts off while running)
Battery is great, alternater is good, plugs and plug cables are good.
I'm assuming the ignition is bad again. Should I assume the mechanic is replacing with generic parts when it should be genuine Honda parts, being that it seems a lot of people are having this problem? Please advise, thank you.
Friday, January 2nd, 2009 AT 3:52 PM
KHLOW2008
  • 41,814 POSTS
Hi goblette01,
If you have not checked the PGM-FI main relay, it is known to cause intermittent failing which fits the description of the symptoms.
Monday, December 16th, 2019 AT 10:34 AM
GOBLETTE01
KHLow2008,
Can I check the PGM-FI myself or do you need certain equipment?
Thanks for your help.
KHLOW2008
  • 41,814 POSTS
Hi goblette01,
You only need a test lamp and some basic tools to remove the relay. I usually just unplug the PGM-FI relay unit from its housing without removing any other things, however you need to remove the fuse be prevent accidental shorting it.
Check the relay circuit board for cold solders, especially at 4 points, 2 on each end. Resoldering them sould do the job if there are cracked.
https://www.2carpros.com/forum/automotive_pictures/192750_MainRelayCoverOff_1.jpg
https://www.2carpros.com/forum/automotive_pictures/192750_PGMFIRelay93Accord_1.jpg
