1992 Honda Accord Please Help!
FURBABY
  • 1992 HONDA ACCORD
1992 Honda Accord 6 cyl Two Wheel Drive Automatic 163k miles
Ok im not really sure what is wrong with my car. It will start run for a bit then die. We have replaced the coil and checked the distributor. I had it at a garage and they say its a fireing problem. My check engin light is not on either is the matince required light on. I was told that it shouldnt be the compiter then. Im not sure where to go from here, could it be the fuel pump or what? Please help I need to get it running so I can go to work.
Tuesday, August 19th, 2008 AT 1:43 PM
KHLOW2008
  • 41,814 POSTS
Hi FurBaby,
If starting fluid can get the engine started, it should be a fuel problem. Check the main relay and fuel pump for fuel supply.
Check for sparks at plugs by pulling out a plug cable and attaching a spark plug then crank engine. If no sparks, you need to check for power supply to distributor. If power is present, the ICM should be faulty.
Thursday, August 21st, 2008 AT 1:15 PM
