1992 Honda Accord Engine Stalls at low speed
SOUTHENSOLDIER
  • 1992 HONDA ACCORD
Engine Performance problem
1992 Honda Accord 4 cyl Front Wheel Drive Automatic
My 92 Honda stalls when slowing to nearly a stop. I was told that it was because of the 10% ethynol in the fuel that this happens in older cars. I tried the Lucas fuel treament, but it onl worked for a week or so.
Is there another solution to this problem, overhaul, O2 sensors, plugs or somthing? Or a double dose of fuel treatment? Any answer will be helpful?
Saturday, July 26th, 2008 AT 12:46 PM
Does it have a check engine light and when was the last tune-up?
Have the electronic air control valve and throttle angle sensor checked out to include a fuel pressure check
Saturday, July 26th, 2008 AT 4:44 PM
SOUTHENSOLDIER
The check engine light does comes on after about 20 minute of driving. It's been a while since I tuned it up, but there is not irratic idle or spuddering.
Saturday, July 26th, 2008 AT 10:14 PM
Pull the computer code/s and comeback with it-The computer has identified a problem within the engine management system-we need the code/s this is where we start
Sunday, July 27th, 2008 AT 11:34 AM
SOUTHENSOLDIER
Ok, the codes it have are: 2 and 43.
Tuesday, July 29th, 2008 AT 4:15 PM
The codes you have relates to the fuel system-for a start get the fuel pressure and oxygen sensor checked out-
Tuesday, July 29th, 2008 AT 4:40 PM
